Vintage Don
Here's another pretty "mundane question".........
This afternoon I stuck the new shocks on the front end. I found that the nice thick new rubber bushings do not allow enough room to get the (fairly thick) washer / keeper, and the (also thick) cotter pin installed. Top and bottom, same problem.
There is no obvious way to compress the rubber bushing. It's rubber, it bounces back - and it's pretty stiff stuff anyway. There's no nut not to draw it down, etc - just that fixed length of the stock shaft for mounting it.
I think I could probably get the cotter pin in without using the washer, but I feel like it needs a steel washer, not just a cotter pin trying to hold against rubber.
So I was considering pulling the shocks back off, and grinding down that rubber bushing on either side, try to gain maybe an 1/8" or 3/16" combined, between the inner and outer faces of the bushing where it sticks out - so that I have room to install. It's definitely not going to go back together as designed without making some room somewhere.
Anybody have any thoughts on this? Is grinding away some of the rubber a bad idea?
See, I told you it was a mundane question! haha
