This may apply to everyone here so I will likely cross post it in the general thread.
Yesterday I figured out how to restore those pesky frozen push buttons that are on your glove box and under seat doors.
Start by removing this clip with a very pointy object. I used an awl.
Its small! Note its direction of install.
This will allow the button to come out the front. If its frozen, add some oil, pry the latching finger up and gently coax the button out. This one was damaged heavily on the side and had the common dented in face. I wasn't able to remove the side dent completely on this one, but it was an extra, so I used it as my tester.
First gently bend this tab out
Make a dolly. I used a bolt. It required a bit of sanding to reduce its diameter, and I also put a crown in it.
Insert and gently tap with a flat face hammer in a swiping motion as you spin the piece
Next clean, grease and put it all back together
I did 3 yesterday. The far left is before, middle in process, right is completed
