I've heard the standard tail lights for the Wagon are often too dim.... What are some of the best solutions?
After disassembling my housings, I find that statement surprising.I thought reflector housings for the bulbs would be a big help, but not worth the effort.
Me too.... I cut what kinda looked like a Royal Red Cross Medal with a hole in the middle from a piece of mirror stainless and folded it up to form the housing. Thought for sure it would help. Didn't for me.After disassembling my housings, I find that statement surprising.
You gave yourself a medal for doing that!?!?Me too.... I cut what kinda looked like a Royal Red Cross Medal with a hole in the middle from a piece of mirror stainless and folded it up to form the housing. Though for sure it would help. Didn't for me.
Of course! If you do come over. I will let you pin the medal on my.......You gave yourself a medal for doing that!?!?
Don't make me come over there...
LOL!!!!!half-voltage folks,
You low amperage guys are all the same with your little wires.EDIT: for the half-voltage folks, check the power requirement of the LED bulbs. Many will work with 6 volts.
That's interesting that red LEDs were better, I'd have thought white would be brighter coming through the lenses.I've experimented with solutions for decades. Red LED's behind NOS lenses seem to be the brightest, or at least the most noticeable difference between the tail and stop lights. The reproduction lenses are noticeably duller/paler when the light is on. You don't need a special flasher if you leave incandescent bulbs in the front. Make sure you have VERY good grounds. The double bright bulbs aren't bad either. ...[/URL]
What about us guys that went 12V but kept the stock wires? That mean we have big wires and twice the juice!You low amperage guys are all the same with your little wires.
Coleman, take a look at this thread. There are a few tips on reducing the dimness in tail lights. Good luck!I've heard the standard tail lights for the Wagon are often too dim.... What are some of the best solutions?
