The points are on the undersidde of the distributors cap correct? Correct. If you take the cap off, you'll find the rotor (the big plastic piece on the center post) and you'll find the points. These are the silver looking contacts that are held down with a couple of screws. The ones you say your neighbor adjusted to .020".
There was some fried wires in the distributor that I replaced. Ok, one of those was probably for the condenser that you said you replaced and the other comes from the negative side of the coil hook up down under the plate. Replace those points. It's less than 5 bucks. You'll get grease with them.
1. take the rotor off the center post
2. clean off the post
3. put a bit of new grease on the post and install points
4. Grab the crankshaft pulley and rotate the engine just a bit to turn the distributor shaft so that one of the lobes opens the points. Adjust the point gap to .020"
5. put rotor back on the center shaft and install the cap and wires.
Also the balast resistor, isnt that integrated into ignition coil? When i bought the coil the guy at napa said something about looking for a ceramic resistor and that if i found one to be that coil back and that I would need a different one. Yes, the balast resistor is the ceramic piece. It's usually mounted on the firewall under the hood. Find the wire on the positive side of the coil and trace it back to the ignition switch. No resistor found? Put one in. Another 5 bucks.
but I marked all the wires and its position so I hope I will be okay there. Me too.
I can smell gas under the hood after I try to start it a couple of times so I would think that it is getting fuel. More than likely.
Ok, so now it's time to check things out.
1. go for a start
2. No start? check for spark at plug.
a. Take out #1 plug and put the spark plug wire on to it.
b. Remove the coil wire from the distributor and ground it so it's not sparkin' up a storm. (fuel vapors ya know)
c. Ground the plug to clean bracket or clean spot on the engine block
d. have somebody crank the engine while you look for sparking at the plug.
KEEP YOUR DIGITS AWAY FROM THE FAN IF YOU WANT TO KEEP YOUR DIGITS.
3. Still no spark?
a. unground the coil wire.
b. have somebody crank the engine. Is it sparking good? Yes? problem is from the distributor on. No? bad coil.
4. Just for gee whiz, if you go through all of this and still have nothing -
a. put it all back together and...
b. put about an ounce of fuel in to the carburetor and try it.
c. If it fires you know it was a fuel problem to begin with.
d. If it don't, you're back to the electrical side.
At this point (and this is just me flappin) you might want to track down those hot wire friends of yours and beat em' to a pulp. (Just a thought).
Steve
