Willysfan
I'm working on a 55 wagon and wanted to up-grade the front differential. Not wanting to spend the big bucks on a Scout 44, I'm considering a Dana 30 from a early CJ. Will keep the 4:88 ratio to match the stock rear 44. Is this a good choice and has anyone made this modification. Got this info from JP Magazine
81 1/2-'86 Jeep CJ Wide-Track Dana 30
Differential Location: Passenger side
Lug Pattern: 5-on-5.5
Good For: Slight strength upgrade for '41-'71 CJs and more width (56 inches wide) for '41-'81 CJs running up to 33-inch tires
Pros: Fairly common, factory disc brakes, bolt-in swap for some CJs, lots of aftermarket upgrades available
Cons: Spring-under housing, weak locking hubs, weak U-joints
Identified By: 5-bolt locking hubs, Dana 30 diff cover
I like the idea of keeping same bolt pattern, spring under, disk brakes, and open knuckle. Won't be doing any heavy duty off roading, and this looks like the easiest install. Thanks for any info.
