tiretrx
I really like your twist on your pickup, Robert. While you did things to suit your likes, wants and needs, you still left no doubt what it is, an American icon. Very nicely done, sir.
I didn't like the glove compartment door behind the steering wheel so I removed it, welded in a plate and installed gauges that looked better for me.
You did a great job... I really like the way a small block Ford looks in a Willys...Again, very nice pickup..
I wondered why the purist hadn't got on to me about the grill and then I saw why, no front pictures. I filled in the small holes for the stock turn signals and added larger CJ turn signal lights. I changed the location a little because it just seemed more symmetrical to me.
Robert. When messing with master cylinders on 4 wheel disk brakes, make sure you have the correct proporting valve and not one for disk/drum application. Some master cylinders also have residual pressure valves built into the outlets. A drum requires around 12 psi residual pressure to stop the springs from returning the wheel cylinder too fast. Disc only use 0-2PSI. If you have 12 PSI residual to the rear disk they will get tighter and tighter till they lock up. Then you have to break a line loose to release some of the pressure. Summit racing has inline residual pressure valves fairly reasonable.It has been a while since I posted and thanks for all the support and comments. I read on line where when adding a new or used power steering box that the lines will have air in them...makes sense. So while sitting still I would turn the steering wheel from stop to stop. I did this 8 or ten times and got the air out and the steering is fine. I added a Old Man Emu 2" spring lift to the rear and now it is sitting level, not nose up. I lost my brakes pulling out of my driveway. Bad master cylinder so I did some research. It had a stock YJ Jeep master with a booster. Got on a Jeep forum and found out the master off a 1979 and up (?) Ford or Mercury big car was a bigger bore master and would give better braking for the rear disc. I got the Mercury Marquis. Had to bend up some different brake lines to hook it up and am now waiting on my bleeding partner (wife) to help me. I have a slight vibration coming from the driveshaft. I cut the Explorer shaft and slid a cut Jeep shaft in it and welded it together to mate the Explorer rear and Jeep transfer case. I think I can get it balanced and it will eliminate the vibration, again it is slight, I can feel it, not hear it.
I have been into Jeeps all my life and I saw how to balance one myself. Use a SS hose clamp. The screw mechanism may be enough weight . It is trial and error to find the place it works. I think it is straight since I slid one into the other and it was a tight fit and I slid it in about 4 inches.
Pump the gas pedal a little and the 302 fires up immediately. I love a small block Ford.
