MrBeast
- Jan 30, 2011
- 15
- Willys Model
- Willys Year:
THE RIG:
Ever since I was a kid I have always loved the way the old Willys wagons and trucks look. I had one given to me when I was 14 but my dad would not let me bring it home. Well much to Dad's shagrin, I gots me a brand new old ride!
I bought it back in June, and have been collecting parts for it since that time. Currently I have:
90 model Chevy TBI 350
99 model NV4500, (clutch pedal, brake booster and steering column from same truck) Dana 60 front axle, and a Dana 60 rear
I also have my choice for a rear axle of a 77 model 14 bolt
94 model 14 bolt
or a 93 Dana 70HD
Not sure which axle is getting installed, but we will see, for sure the list of mods is going to include 4 wheel disc brakes, using GMT800 rear discs and calipers so I can have a functional E brake, as well I am going to install a Mico Brake lockhttp://www.awdirect.com/lever-lock-mico-brake-locks-02640125/brake-locks-pto/ on the front axle so I can lock up all 4 brakes to give me a really good bite if I am ever in a situation where I am recovering another vehicle because I do have a 12,500 lb Warn that is going on the front bumper.
THE TRIP:
The plan is hopefully in 2012 to be able to head out from where I live here in South Texas starting on a cross country adventure that will take me to Alaska. The plan is to get to see as much as possible, and be bloging about it the whole way sharing photos and videos from my adventure.
Once in Alaska, I am going to explore the place and hopefully wind up finding a piece of land where I will eventually build a cabin.
Coming on the trip with me will be my best buddy in the whole wide world Dexter
And my Girlfriend Kena.
Other stop offs along the way are planned in Yellowstone Park, and Glacier Park, Might do the Grand Canyon as well.
ACCOMIDATIONS:
Once the Willys is up and running I am going to borrow a few trailers and see how much trailer it will tow. The wheel base on the willys is going to be stretched out to 110-112" so this will help, as well the willys is going to pick up about 2-3000 lbs with all of the running gear I am installing, and with the bumpers, engine upgrade and frame reinforcement.
Thus it will be hard to tell exactly how much trailer it will be comfortably able to handle.
The idea though is once I know about how much trailer it will take I am going to go get an older airstream trailer and refurb it.
When doing the airstream refurb the trailer body will get yanked off of the frame, a new frame will be constructed that will be much stronger than the original, and then instead of putting the soft belly skins back on, I am going to run aluminum diamond plate on the bottom, and I will also wrap the front corners in it to keep the trailer looking nice.
The trailer will also get the largerst tanks I can stuff in it, a tankless water heater, the largest propane tank I can fit, and it will get a onboard gennerator.
Inside the trailer will be totally rewired and then insulated with spray foam making it esentially one big giant aluminum beer cooler, so that should make it quite a bit easier to keep the temperature under control. As well all of the tanks will be mounted in the warm zone of the trailer, so when I inevitably get the wild hair to go somwhere cold during winter freezing pipes will not be an issue.
I am also going to design the water system so there is a drain at the lowest point in the pipes, and when that drain is opened the pipes will drain completly, and there will be an air fitting on the other end to be able to blow them out of nessasary.
As well I am going to open up the wheel wells on the Airstream to run the same size tires as the Willys, I will use big truck fenders to remake the wheel wells so as that I can have them fit nice and look right.
When it is all said and done I think it is going to be a mad cool rig, and now here for the build updates so far:
94 model 14 bolt
or a 93 Dana 70HD
THE TRIP:
ACCOMIDATIONS:
