There were improvements in the plate retention during production in several steps, so later is better, but you can do the upgrades Greg suggested. I have a later engine apart here and it has plate dowels I don't think the earlier engine has - does yours have those Greg? They are on a service bulletin. This engine also had the service bulletin "hook" around the water boss for the upper left timing cover bolt to have something to attach to.
They made some casting changes in the head for plate support and drainage. The last pn head seems to be the same casting as the military head (different machining) and is noticeably better. As well as a boss cast in for the extra bolt into the head on the passenger side the it has an extra boss cast into the drivers side and the upper left timing cover bolt is directly into the head, better still than the hook. This head also has a cast passage on the front passenger side for oil drainage the earlier heads don't have. I think you could re-machine a military head if you wanted to and you were careful.
I don't have the engine together yet but I'm going with Greg's experience that it's a very good engine, and very pleased to have scavenged a NOS last production head with the extra features.
As a point of interest I stuck the head on the flowbench and it is amazing. These things were intended to make power.
Also very pleased to hear you can cruise at 70 Greg, not really planning to but I was hoping you could drive it on the highway. I'm going with the Bendix drum brake upgrade to get both shoes to actually work and keep the stock look, think it will be good, but time will tell.
