My first mistake was in removing the tires. As it turns out, 3 were right hand threaded, and 1 was left hand threaded (not discovered until I had twisted off 3 nuts.) Today we pulled it slowly with another vehicle with it in 1st gear, the first 2 times I disengaged the clutch the motor did not turn, but on the third it broke lose and began moving. (I had removed the spark plugs and squirted penetrating oil in each cylinder a week ago.) Once the pistons were moving freely, then we tried the starter, which worked.
Next I checked to see if we were getting spark, and did not see any. I downloaded some diagnostic steps and here is what I found:
Coil + to - resistance with everything disconnected - it was not constant, it would jump between 5 ohms and as high as 120, but mostly 5-20, and would not stay constant as I would expect.
Coil + to center - 5,500 ohms stable.
At first I did not get spark out the coil, but cleaning and reconnecting I managed to see/hear some spark - although I can't call it strong. Then reconnecting everything and checking for spark at the spark plugs, I see spark, but again it seems weak to me.
We tried starting, I only had a little starter fluid left, and it acted like it was trying to fire. I was out of starter fluid, and switched to squirting gas in the carburetor, and get nothing, it cranks but doesn't try to fire.
I will get a new can of starter fluid and give it another go, but with this information can anyone tell me if I'm getting the spark I should?
And please, anyone who has advice, please post. My immediate goal was to get it running, and drive it around for a few days, before moving it into the garage and stripping it down to the frame and working back up from there.
