Boy, I am stupid and incorrect. I chided someone when they said the 161 is just a longer version of the 134. I thought incorrectly that can't be true because with 2 more pistons added to a !34 you could not get to 161 cu. inch. But I am very wrong, and I apologize to Digger and all others. Firstly, I discovered the 161's have around a 1 inch shorter compression stroke compared. Second. I knew this, the 134's have a wide water jacket area in middle of the engine that probably adds an inch and a half to its length. The 161's do not have that. So when you do those two things different you can get to 161 cu. inches.
I never thought the 161's compression stroke would be so different but it is. So that is how the 161 and 134 pistons etc. are the same. The 161 is just a longer version of a 134 with a much shorter stroke!! My bad!!!
peewee
