The VinFast looks to be a smaller sibling to the new Bronco, styling-wise.
Good news!The latest from our son a few minutes ago:
Yeah, he just sent a note that they made it to the charger. Whew!Good news!
California says that you shouldn't warm your car up. It's not good for them.They’re charging the car now just outside of Billings, where they’re staying tonight. This way they’ll have enough power to pre-warm the batteries in the morning (the car can be set to do this automatically) and then they can top off the charge before heading out.
My car was coated in ice yesterday morning. I definitely let it warm up.California says that you shouldn't warm your car up. It's not good for them.Whoever said that has not had to pry a frozen door open and scrape a foot of snow off the hood and windshield.
When you have not changed out the leather straps in a while on the Con Rod bearings, you might see a drop in oil pressure.Did I see that right. "While idling the oil will drain away from key components". In what alternate universe does an engine not have oil pressure at idle"
Some of these old Willys engines have almost no oil pressure at warm idle.Copied From MSN News Feed.
The bottom line is that it's a myth that you should warm up any modern car before driving in the cold. Oil is essential for lubricating the engines of gas-powered cars. When you start your vehicle, it takes the oil pump about 20-30 seconds to fully lubricate the engine.
While the engine may not be completely warm within this time frame, it is ready to drive. However, if you let your engine idle for several minutes, the oil will drain away from its key components, which could increase friction and cause wear and tear. As a result, many car manufacturers recommend starting the car, buckling in, and driving off almost immediately.
I have a winter front for the Ram, it's not installed but have it if the Polar Vortex hangs out for a few weeks.Wow, and for the last 60 years I've been driving, I've been trying to never move my vehicle after starting until 3 minutes have passed. The time it takes to smoke a cigarette as my adopted uncle Art would say. And when it's actually cold, it's time to remove the cardboard from in front of the radiator before driving. Anybody still using "winter front's over their grill? Asking for a friend.
Natural gas is already replacing coal for power plants on a global scale cuz it’s cheaper than coal and the natural gas plants are more flexible / useful. However, some countries are still building coal plants because they either have coal or control access to coal.I would like to see Butane used. And natural gas replace coal, world wide.... But, whatawino?
