cwdtmmrs
- Jul 19, 2012
- 5,999
- First Name
- Tim
- Willys Model
- Wagon
- Willys Year:
- 1952
It's worth noting that Tim's wagon has the bell crank (crossover) drag link, which improves steering geometry overall (and is an advantage that's also gained by converting to a more modern box).
At this point, since good new parts are mostly not available, the service required on most stock Ross boxes is closer to remanufacturing than rebuilding. You need to be resourceful and find a machine shop that can do the work. Even after remanufacturing, it's still an antiquated unit that was primarily used on lawn tractors, with a certain amount of slop that can't be adjusted out. The Ross manual states that "backlash in the end positions is normal and not objectionable".
I've also seen enough stress failures of 70-year-old steel and cast pieces to have some concerns about trusting them. It doesn't keep me from driving my wagon, but is something I think about, and is making me consider alternatives. From what I've seen, every option generally requires some custom work. Nothing is 100% bolt on.
All true. I still think that the Ross box is adequate with a stock motor and stock tires. I think properly built and adjusted you have approx. 45*-55* straight ahead steering with minimal backlash.
