- Oct 5, 2020
- 754
- First Name
- Fred
- Willys Model
- Wagon
- Pickup
- Jeepster
- CJ
- Willys Year:
- 1946
- 1948
- 1950
- 1955
- 1961
Joe also uses Zelle.okay how do I pay for it Paypal?
Just email Joe. I think I ended up sending an old fashioned paper check.okay how do I pay for it Paypal?
its probably junk, good seal will have a spring load on the lipe and a wiper ring, if it does not , toss it and buy a C/R brand seal...PhilI order a seal from Ron's jeep parts.
You should tighten the nut to whatever torque you feel comfortable with. In your first post you asked what the recommended torque is, I posted it directly from the CJ5 manual. The torque values are there for a reason.I bought a seal puller and a steering wheel puller from Joe. He take venmo. Also when I tighten the nut that holds the yoke why does it have to be so tight. I would think about 75 pounds?
Part of the big problem is Crown, as they serve a need, but they also flood the aftermarket with cheap low quality parts. Seals and bearings is one place where cheap is not better, and every off-road store sells this junk. It makes no sense to spend 4 hours labor, 100 bucks in tools and fight tight nuts and then use lucky Phils off road parts (from Crown) and put in a cheap seal that will leak in the first hour. Where a 20 buck C/R or spicier seal will last 25 years...PhilPhil brings up a great point. Many of us have non-automotive mechanical (machine repair, etc) backgrounds and have learned not to trust bearings or seals from “standard” automotive suppliers unless they are of certain trusted brands. Lately, due to mergers, off-shoring, greed, etc, it’s difficult to find quality parts, but you should still try. The internet has been a force for good in that area.
I have that puller and you can borrow it if you don’t want to buy it. Just pm me if you wantokay how do I pay for it Paypal?
Np. Saw that after I sent the postThank you I got the yoke off with a 2 jaw wheel puller. I ordered a seal puller from Joe and waiting for that.
Just need to figure out how to back up the yoke and stop it from turning as you torque it. I built a plate to hold it, works good. You can also bolt a short piece of chain to one of the holes in the yoke then connect it to something solid.The hard part is torking the nut under the jeep to 175 pounds
