dekeeb
While working on my 1955 pickup today, I decided to peek under the trasmission tower to see what I could see. I recently got the engine running for extended periods and was able to run it through all its gears without much difficulty, and it did what it was supposed to do albeit while up on stands. I suspect the transmission is all original as the casting date on the case read Feb 1955, and the assembly date on the top of the case read March 25, 1955. The photos below give you an idea on the general condition of the gear sets, my question is this: Do I go ahead and rebuild, or just leave well enough alone? I’m stripping the truck ahead of frame work, and the transmission and transfer case leak like they’re 68 years old. If the odometer on my truck is accurate to when it was parked, there are just over 40,000 miles on the old boy. I’ve included a few photos to let you register your opinions. If I do undertake rebuilds, it’s beyond my comfort level to do myself so a shop would be going the work.
