Mark W.
I need to talk with someone that has a 134F and the FACTORY spin on oil filter setup.
Walcks sells the "top" that works with these filters but only shows a single view which makes it hard to see if I can adapt it to what I want to use it for.
Walcks number is 929838 says it was used on these rigs
CJ3B 1960-1964, CJ5 1960-1971, CJ6 1960-1971, Pick Up Truck 1960-1962, Station Wagon 1960-1962, Sedan Delivery 1960-1962, FC 1960-1964
I am trying to figure out if I can mount this so the filter hangs and the whole mess mounts in the position of the Fuel pump (which is not being used) on my Hot Rod 134L Some photos of one mounted would help so I can see how its attached. I know all about using the proper by pass style filter (NAPA #1050 Fram PB50 etc) Since the filter would be located lower then the galley I don't think any worry about a drain back valve one way or the other would matter.
All help will be appreciated.
