Obviously at this price, this will be a later on project, but I do prefer the floor pedal setup as the PO modified the setup with an XJ swing pedal, booster/master and Wilwood style clutch. I do like the mechanical advantage but this looks to be a great way to hide it all and take my CJ back to a more stock appearance.
This brand is a subsidiary of Wilwood, I imagine the quality to be good if not better than what I have.
Or for some savings, if I can verify room for clutch action to still work, I could go with this and upgrade the clutch to the Advanced Adapter chain setup.
TCI 600-6571-56 Under-Floor Manual Brake / Hydraulic Clutch Assembly
Want to put a manual transmission in your street rod? These universal pedal assemblies offer a clean, simple way to mount your brake master cylinder and hydraulic clutch master cylinder to the frame, under the floor. Kits include a bracket and pedal arms (pedal pads not included but are...
www.speedwaymotors.com
Universal Brake Pedal, 7 Inch Booster, 1 Inch Master Cylinder
Learn more about selecting the proper master cylinder for your vehicle by reading our tech article, Brake System Selection Universal bracket assembly converts under floor mount master cylinder applications to power brakes Power brake pedal assembly mounts to inside of frame rail or boxing plate...
