What is the best way to hold back the drive tran while torquing down the drive nut on the Warn Overdrive . I have the whole unit ( trans & transfer) on a work bench. Having a clutch disc on the output shaft and strapping that or clamping in a vice would work . I recall that one could put it in two gears at the same time and lock it up. Like reverse and second or third gear not sure if this would damage the gears or syncros. Other than that like Lookout suggested having it in 4 wheel drive low range and possibly hold down one or both yokes. My main goal is to install this overdrive on the work bench and not under the vehicle. That way I can insure that the special lock plate and snap ring are installed correctly. A 100 to 120 ft pounds of torque should be easy to hold back just want to do it without damaging anything.
