You might find the G503 videos helpful also. Not a truck but am guessing the concept is pretty much the same.Scott has 2 different videos to cover the clutch and brake. But they are tied together so if one is off that impacts the otherHey Roy. One thing I see is the green rod is at a cross angle. Both ends should be with the cotter keys towards the frame. That said , unless it’s causing a bind or something not sure if that would be an issue. I did read there are 3 different rod lengths depending on which vehicle. From about 9 3/4”, 10 1/2” and 11+ “. If wrong it will drive the clutch cable to be wrong as that tab will be in the wrong place. The 12-2 o’clock position. Yours looks like in the 10-12 o’clock
