peeweecash
I have a 2 wheel drive jeep which had a L-head 134 4 cylinder. I am upgrading to a willy's 161 F-head. On a 134 the throw-out bearing arm comes out through the side of the bell housing. The 134 fly-wheel is about 12.5 inch diameter. The 161 flywheel is 13 inch diameter and the 161 clutch does not come out the side of the bellhousing. It is different. My 161 engines came from willy's Aero cars. Now the Aero engines will bolt up to a Willys transmission with some questions but like I say they do the clutch different from the jeeps.
So here are my questions. The bell housing on the Willy's Aero cars do not have the throw-out bearing lever coming through the side of the bell housing like Jeep vehicles. If I use (or can I use) the bellhousing from my 134 so my clutch stuff stays the same, with my 161? Does this mean I need to use the 134-fly wheel and 134 starter and 134 bellhousing on the161 engine? If I could, I would like to use the 161 starter since it is a solenoid starter and I know all that stuff works). No kick starter foot button. Seems like the off sets from 161 starter to a 134 fly-wheel will be different, not to mention the number teeth on the flywheel are different too. Can I use the 161 flywheel and starter with a 134 bell-housing? Do I need to find a 161 bell housing from a truck or station wagon which might have the side throw out bearing opening? Then everything will work?
Or is my only choice to use the 134 bell-housing, flywheel and 134 starter on my 161?
Bill
Bill
