Kjetil,
The 226 is a bit of odd duck, in that it can't be a tooth off. The distributor shaft is a slot fit with an off-set side.
Your firing order is 1,5,3,6,2,4
Here are some pics. The engine bay pic is from a friends 55 pick up. Note that the number 1 wire is pretty much straight ahead, then go from there with the firing order in a counter clockwise rotation.
It is possible that your timing chain could have slipped but I doubt it. This is a bit of an odd duck as well. If you have the #1 cylinder at top dead center on the compression stroke, the alignment marks on your timing gears need to be 9 links apart. The alignment marks on the gears DO NOT line up with each other.
You should be able to click on the pictures for enlargement and be able to read them.
Hope this helps you out.
