Windshield Wiper Motor (electric)
I inherited an electric wiper motor on my '62, works fine-look's fine, but disappointed it has only one speed.
rcshook696 said:
Hey BioTek, check out Kaiser Willys parts. They got conversions kits for $159. Here's the link - http://www.kaiserwillys.com/category/wi ... ersionkits Looks like a cheap switch, 2 speed electric motor, uses your cables. I think they have about all the parts for wipers. They will also send a free catalog. rcshook696
Glad I didn't already send the money off. Thanks for the tip! I have their catalog, but for some reason didn't look in it. The truck is going to end up in Florida when it's finished, so I need a good quality wiper system. The Kaiser Willys folks are good to do business with.
I'm a little late to this but thought I'd throw this in. Someone converted mine years ago and used what I think is a late 50's Chevrolet wiper motor that bolted up to the original metal on the firewall, the original drive key was cut off and a rectangle shaped piece of steel about 3/16 thick x 1 inch wide was tack welded on to the shaft to fit the original willys drive slot and the original on/off cable was hooked up to a plastic slide on the switch for 2 speed operation. Mine is 12 volts and works great. If you have access to some 50's junk parts maybe something would work, sorry I don't know for sure what it's out of but I've seen late 50's wiper motors like mine on Chevrolets.
Couple more thoughts...
www.wiperman.com does an excellent job of rebuilding the vacuum motors. I have one and it works as fast or faster than the electric wipers on my regular cars. You can install a vacuum cannister to eliminate the slowdown when on the throttle.
And, if you are looking at doing a conversion, have a look at the GM motor that Midnightburn did on his wagon. Looks like a very clean install.
http://www.wiperman.com does an excellent job of rebuilding the vacuum motors. I have one and it works as fast or faster than the electric wipers on my regular cars. You can install a vacuum cannister to eliminate the slowdown when on the throttle.
Pete,
I don't have the original wiper motor. I also live 420 mi. round trip from a salvage yard. It is easier for me to just order a complete motor.
One of my major goals on this build is to not perform a modification that can't easily be reversed. If I had an original vacuum wiper motor, I'd definately use it.
BioTex said:
Pete,
I believe the Wiperman also sells rebuilt vacuum motors, they may have yours. Nothing wrong with the electric conversions, but I've found them to be much more expensive.
Pete said:
BioTex said:
Pete,
Ok, thanks. I'll check into it.
Now that I have the BBcode working for youtube clips, here's a clip of my vacuum wipers-
[youtube:8zlk4s4p]zd0ApFGDlbc[/youtube:8zlk4s4p]
I used one of those wiper power units from New Port Engineering in my '55 pick-up,hock right up to the cables and used the original mounting holes,has a 2 speed switch w/park,just make sure the cables are tight.I'll dig around and see if have an extra set of cables and towers. Jim
