Willys engine
nmgumina
Knuckle Buster
Oct 13, 2020
3
San Diego
Natalie
  1. Other
  1. Other
Trying to find out if anyone knows what this Willys engine was for. Found it in my garage and would like to to go to a good home if possible. I figure someone may be looking for one.
Sure, sorry I can't get that one wire out of the way but here are a couple different angles.
Military gen set engine, every one made them, for gi contract...Phil
So then is it a junkyard piece or do you think anyone would want it?
I bought a basket case mule. Did not come with a engine. Thats the engine I need. Let me know.
Thanks Brad
I have a similar engine. Its data plate gives model number, serial number and cu inch. Mine is a 4 cylinder, 32 cu. inch, aluminum engine used in a military generator. I bought it because I thought it would make a good ultralight plane engine. weighs about 55lb. I think they have 4 cylinder around 56 cu. inch again generator engine. I kind of looks a hair different than mine. so maybe it is the 56 inch-ish engine.
peewee
PS. Mine is a Continental engine which is actually a small copy of aircraft engines but used in military generators.
