What the heck is this hole for...?!?!
sstach
Mar 11, 2010
398
Central IL
Can someone please tell me what this is for? I’m using the hole at the top for thermostat. Not sure I need this one. But I can’t find the right size plug for it. I keep trying, and now I own more brass plugs than I ever wanted! Ha ha. Any ideas? Can someone reassure me what plug will fit, and maybe it’s just dirty threads?
Thanks in advance!!
sstach
Mar 11, 2010
398
Central IL
Sorry. Could have been more clear. I’m talking about the threaded hole on the side of the head. Thanks.
Vintage Don
Oct 9, 2017
1,831
Medina, Ohio
Don
Temp sender, yep. Looks like you've already got the bushing piece in there, so it would probably take the threads of the original style sender, whatever thread size that might be.
sstach
Mar 11, 2010
398
Central IL
Thanks. I thought so to, but I can’t get it to go. Plus, it feels like the end of the probe is butting up against something in the head. Could that be possible?
sstach
Mar 11, 2010
398
Central IL
I’ve temporarily put the temp sending unit in the hole on the top of the head. But I believe that’s where a valved insert goes? Maybe for a heater?
Big Dog Frank
Feb 12, 2016
1,718
North Lawrence,Ohio
Frank
In my limited experience I found that port to be too shallow for a mechanical gauge sending unit to be inserted. The origional sending units were for electric gauges and were very short.
I do believe the port you are trying to use is where the heater hose would connect. I am not sure how accurate of a reading you would get at that point.
Good luck with your work.
Bill Norris
Jan 31, 2013
303
Michigan
Bill
CJ
As far as I know, the l-heads were all mechanical gages. The sender will bottom out, that’s the way it was designed. It’s not too shallow.
The hole on the top of the head you are referring to is for the valve to turn coolant on for the heater.
Bill
Sam H
14
Kansas
Sam
Jeepster
Thanks in advance!!
Looks like the temp guage hole.
45cj2a
Jun 2, 2017
1
Waddell,AZ
Michael
CJ
Other
Thanks in advance!!
If you didn’t remove the sender, the bulb might have broken off and still be in the head.
jde
6
PA
John
CJ
My 1947 CJ2A during disassembly. This is where my probe was for the temperature gage. See above distributor.
