Truck Dynamat roof installation
It was a video of a comparison between the stuff I used against dynamat and several other name brands that made me go the direction I went. One thing they did is to burn them with a torch to see what happens and they all burned at about the same rate. Dynamat as mentioned, is also a butyl type substance, same as the material I used. I just urge people to do a comparison, it's so must less expensive, it's worth buying a roll, buy a square of Dynamat or any other name brand stuff and compare for yourselves.
Less expensive than KilMat? Not really. Your roofing material was 160 a roll: 7'x36"(I think that was the cheapest I saw it for) plus it's half the thickness of the 80 mil deadener products.
And this might be my new favorite. Came today and outweighs the KilMat box by 3lbs for the same 3.6 sq ft. 60 bucks
Plus it's black so if you left it exposed like on the inside of a truck cab, you wouldn't feel like you're riding in a turkey roaster
What is 160 a roll ? you mean $160.00 dollars ?
Basically it comes down to what you're trying to do; so what are you trying to do?
Once again, let's look at vehicular insulating materials:
Dyanmat (and all the other butyl products) is a sound deadener. This means when it's properly applied it will absorb the micro-vibrations in the metal that amplify sound. Think of it as a damper... It's a great underlayment to what ever else you use to insulate. My favorites these days are KilMat and Siless, both around 1.60 a sq. ft. (compare to the roofing crap mentioned above at 7 bucks!) and you can buy them in small packages thus eliminating waste. (compared to the roofing at a min. 7' roll). Also, could not find how thick the roofing stuff is, I would doubt it's the 80mil thickness of the automotive product.
Next you would have sound absorbers. My favorite is 3M's Thinsulate (yes, same stuff in your jacket) . It comes in two thicknesses for automotive use; 1" and 2". Obviously, the thicker the better. Not only does it do a good job at absorbing sound, it also has great thermal insulating properties. Something to think about when the sun is beating down or there's snow on your roof. It attaches fast and permanently with 3M's spray 90 adhesive. And it's totally hydrophobic, so condensation won't be absorbed like it can be in carpet. There are other materials like sheep's wool and recycled denim if you're going for a "green" feel. They work well from what I hear...
Then there are sound barriers, the best being lead but it's expensive and really heavy. The stuff I prefer is called Mass Loaded Vinyl or MLV. It has a density similar to lead but less expensive and easier to work with. But, both of these materials need to be decoupled from the metal, and you would use a Closed Cell Foam, or CCF, for that. If you don't, then the sound just transfers from the metal (firewall) to the material and into your environment. MLV makes a great firewall sound barrier, but it needs to cover it completely to be very effective, which means cutting to fit and taping all of the seams. You can buy it with a layer of CCF pre-bonded to one side to make th installation easier. And again, goes up permanently with 3M 90. Though I wouldn't bother with it on your roof.
Last but not least are the hybrids that include Noico's "Red" (a CCF material) and Lizard Skin, a spray-able coating. The first is an interesting product, I have some but haven't used it yet. It's a type of CCF that claims to be both a deadener and absorber and thermal barrier. OK.... but is it good at all 3? Dunno.
Lizard Skin gets mixed reviews. Some folks are all in and will tell you it's better than sex, but I've paid less for good sex; Lizard Skin ain't cheap! I would like to try it myself if I had the underside and the interior of my Wagon body sandblasted, surface prep is key for that stuff and it needs to be applied to as much surface as possible for max efficiency. Yer on yer own...
FWIW, in my wagon I'm using KilMat where ever I can stick it on (and yes, it sticks permanently to clean surfaces, including the inside of your roof, but get and use a ROLLER!) and then Thinsulate over that. I'm using MLV on the floors and I'll try the Noico Red on the inside of the firewall and underside of the cowl. And when you tap the body panels, you get a nice dull thud.
As far as home materials are concerened, sure you can cheap out and use roofing material, carpet, wood, pink fiberglass, whatever... It WILL do something! And it's better than nothing. But it might just soak up some water and get smelly or moldy or ? Then getting that sex will probaly be off the table after the first ride.
My moto is "buy once, cry once". Go for the high priced call girl or the skank at the stop sign; your choice ;)
Excellent tips. looking to do my '59 one of these days, then I might be able to hear what the passengers are screaming..lol Question is, how well does this deaden the noise? These are not quite rigs by any stretch of the imagination. Between that and the heat from the engine~
Depends on how much you use! AND how well it's applied!! The butyl deadener MUST be rolled down, use a rubber roller, a smooth wood block, your hand and a rag, whatever it takes. And the metal you put it on must be smooth, scrape off all the loose crustys, sand, treat with metal prep (ospho) and paint. Let the paint cure for about a week, then put the butyl on.
Trucks don't seem to have a lot of interior finish. especailly on the aft bulkhead. That's a big expanse of raw sheet metal that acts like a drum to amplify noise. IIWM, I'd use the black Siless brand just for looks, or figure out how to cover it all.
For heat, use the closed cell "hybrid" PE foam products on the inside of the firewall. Noico, Silees, Killmat all make it. Just go crazy on Scamazon.
Then, if you want to make it really cozy inside use 3M thinsulate over all of it, especially on the roof and back bulkhead to keep that Sacto sun from turning your cab into an oven, and keeping you toasty on your winter jaunts to the Sierra !
Awesome advice, I'm going to get on this!
  • Like
Reactions: Jay
BTW, this ain't rocket science. But it is quite satisfying when you close the door and you get a nice solid thud over a bang. (yes, do the doors!!!)
YOu can actually make your Wagon or Truck fairly quiet...
Now a CJ with a rag top? Fugetaboutit!
One last thang:
The title of this thread has "roof" in it. But don't forget the floors! Once they are rust free and painted, cover them with the butyl deadener, (great place to use up scraps), and don't forget the "ceiling" of the tool boxes. Thiwll creat a decent sound barrier but if you want to take it up a few notches, cover all that with a thin layer of CC foam and Mass Loaded Vinyl. Put your rubber mat or your carpet over that and you'll be amazed.
Have fun!
hint: MLV is a sound barrier. But it MUST be decoupled from the hard surface or it will just transmit the sound!!! hence the layer of foam.
Using roofing materials has come up a few times. If it is asphalt/tar based beware of flammability. A number of years ago here a member had an electrical issue that ignited it and he had a full-on inferno going that he could not put out.
I remember that
I covered my entire roof with Kilmat. That stuff is sticccccccky. I haven't noticed a huge difference (although some for sure) in sound dampening/deadening, BUT it has REALLY helped with temperature extremes and keep the interior of the wagon a little less hot or cold. As mentioned multiple times above, get a good roller and make sure to really get it pressed on or the changes in temps will cause the material to release or weaken its bond...plus, it isn't as effective unless PRESSED on with might. I need to do my floor pans and up into the firewall someday.
Right or wrong, my money saving method- Use the sound deadener on the flat metal. I skipped all the places that had "stiffiners" (ie corners, stiffening ribs, places where metal is welded to a support, etc). In my mind you are trying to control or retune vibration and those spots are less prone to vibration. I generally use about 1/2 of the material that most people use. I think I get 80-90% of the benefit. Please feel free to criticize.
PS> One thing I saw that I'm confused about. The article claimed that sound deadening is all about weight. The claim was a 5lb cast iron weight taped to a trunk floor is about the same sound deadening as 5 lbs of kilsmat or other. Is there a lightweight sound deadener that works?
You're right, any large flat area of sheet metal is prone to vibration. But that doesn't mean you won't benefit from adding small patches of deadener in between. There used to be a good website called sound deadener showdown. He originally claimed covering only 25% was effective, but then revised that up to 75% after doing a lot of testing. I've done just about any panel I can reach in my Wagon, including some hared to get spots like under the cowl; made a big dif in my opinion.
So many "articles" out there; which one was that? IMHO, using cast iron is a big stretch...
Most, if not all of the companies make some sort of "hybrid" deadener which is basically dense closed cell PE foam; Noico has "Red" and it's billed as a "lightweight" alternative to butyl. I've used it and find the butyl will be more effective but the foam does do an OK job with thermal. The one thing about insulating for thermal is you do have to cover everything! @CJZuma mentions above getting a thermal benefit from the buytl but he covered the entire roof. He'll get even more thermal (and sound absorbtion) if he covers all that with Thinsulate.
Thank you for your information , I now have a place to begin insulating my 51 willy's . NATE
Thanks for the great info @Tralehead ! Although the Sound Deadener Showdown website is gone, I found this web archive link that has much of his info. I’m exploring it now.
I always spray LizardSkin Ceramic Insulation and then put a Dynamate type of sound proofing. The LizardSkin Ceramic Insulation keeps the heat from making it's way into the cab. The butyl product will help eliminate any residual heat. Just running the butyl Insulation the heat will still make it's way to the foil backing which then has to dissipate into the cab. By doing Lizardskin first you stop the heat at the metal. By doing both you get a cooler and quieter vehicle.
