I believe I have a slow tranny fluid leak (pinkish color see pics below). It appears to be on the bolts and its very slow, could it be as simple as replacing new bolts and washers or a bigger job? Taking it to mechanic soon.
That fluid does look red to me, so someone might have used ATF. Not the right choice but I would replace it with with a quality 90wt.I believe I have a slow tranny fluid leak (pinkish color see pics below). It appears to be on the bolts and its very slow, could it be as simple as replacing new bolts and washers or a bigger job? Taking it to mechanic soon.
Our old ‘48 came with gear oil that was reddish, so it’s not unheard of.
As for ATF, I’m not convinced it would be all that bad. We had an F-150 with a 5-speed manual trans that specified ATF. It’s also specified in the transfer case of our Nissan Frontier (which has a manual transmission).
My speedometer cable leaks fluid. I have tried lots of things and it is still leaking there. Four ounces or so a year with aproximently 1500 miles driven. Most is when i drive it a long distance and the fluid expands more than just riding around town.First, I would look at the speedometer connection
I don't see any fluid above that point
Everyone laughed at me when I said I'm building a leak free transfer case. They were right, I still get about a dime size worth a month.
