Transmission and differential fluid
Kappste
5
Grove, Oklahoma
I’d like to thank the people that responded to my question about transmission and differential fluids. From what I have read the SAE 90 W mineral gear oil (API GL1) from NAPA seems to be the best choice.
But can this same fluid be used for each - transmission and differential. I think it can, but I’m not for sure.
Blue Duck
Mar 16, 2020
281
Western Texas
Stan
Yes it can, the transmission and transfer case are open between the two. The fluid moves between the two as they turn. If you fill the transmission It will flow over to the transfer case. You need to drain both the transmission and the transfer case to be sure you get the case bottoms where any residue collects. I usually put the driver side front tire up on a ramp, easier to get under and ensures better flow as you fill. Fill until fluid runs back out the filler hole.
Bitzf4
Oct 13, 2020
161
Hastings mn
Jim
So you leave the wheel on the ramp during fill? Haven’t done this yet so just don’t want to be under filled when level
Bigbill
Mar 19, 2021
44
Ct
William
  2. CJ
I use a moly additive in gear oil and engine oil. There’s moly gear oil too.
Moly.
Eliminates all wear, it wears against itself.
Reduces friction.
Prevents Galling.
Fights Corrosion.
Blue Duck
Mar 16, 2020
281
Western Texas
Stan
Yes, I put The drivers side front wheel up on a ramp or jack the front end up a little, drain both sides then fill thru the transmission fill hole until oil comes out the transfer case fill. One note, the plugs are all tapered threads, don’t over tighten them. Teflon tape helps seal the threads. Warming the oil up good before you start will make it pump a lot easier.
