For what it’s worth, I was told 80/90w gear oil.Can someone tell me what weight gear oil I need for the transfer case on my 63 truck?
Thanks.
How do you keep it from leaking? PO had Amsoil for all fluids, leaked quite a bit more until I switched to conventional.I like Redline MT90 GL4. Synthetic and it lets my overdrive shift correctly. Something other synthetics didn't always do.
Autocorrect. All fluids. Synthetics leak on older vehicles and seals as you are probably aware.“Ball fluids”? Did you mean steering knuckles? The manual calls for NLGI grade one grease but many folks use a home-made concoction of regular grease and gear oil commonly referred to as knuckle pudding. Have a look here; https://www.oldwillysforum.com/forum/index.php?threads/front-steering-knuckle.20919/
Auto engineer with VW built my CJ5, all components rebuilt/renewed. He went with every Amsoil product that matched GL specs. Very leaky.FWIW I'm using Amsoil 140 wt. in my rear differentials and Spicer 18 transfer cases (one with a Warn OD) with minimal leaks.....but that took some doing with new seals and yokes. On antique stuff that rarely goes over 45 MPH I simply stick with whatever the manual calls for in a traditional mineral oil base that's on sale in 5 gallon pails at the Fleet/Farm type store whenever I'm running low. I use the old used stuff for bar oil in the chain saw, but admit that proper bar oil works better.
A guy on you tube sell's the correct oil, check him under metalshaper, it's not cheep but good stuff, or go find some oil without any additives, a local oil supplier can't get you some.Can someone tell me what weight gear oil I need for the transfer case on my 63 truck?
Thanks.
Synthetic lube leak through paper gaskets and not the seals. the shims are probably the culprit. I lose about four to six ounces of fluid a year driving about 2500 miles. I can live with that. There are always drops here and there from my pickup and that is the worse one.How do you keep it from leaking? PO had Amsoil for all fluids, leaked quite a bit more until I switched to conventional.
Someone mentioned above regarding synthetics and paper gaskets. My MGB has one, I used Royal Purple because it was said to be safe with brass, leaked over time and soaked under the car. They only offer a paper gasket, I'll try it soon with a liberal coating of #2 or Hylomar.Redline is a great fluid and love it in muscle car diffs cause it can really take a beating. I use Royal Purple in my diffs and driveline as the bottle clearly states it is safe for yellow metals and I prefer synthetics. So far it doesn’t seem to leak when parked.![]()
