andyb462
Guys, just wanted to make a quick post on the rear axle from my '47 truck.
Discovered Austin's (@Dual48s) amazing post (Ole & Lena... A Love Story) on this subject and wanted to share my experience.
I took Austin's advice and made a puller for the pinion. My first attempt using a bearing splitter + heat proved insufficient. I made it from 1/2" steel plate and grade 8 3/8"-24 all-thread. This thing worked like a charm, no stripped threads and no bent plate. If anyone else decides to take on this challenge, I highly recommend building something similar (or contact me if you want to use mine). Here are some pictures.
I've also ordered all of the parts Austin calls out (this research and documentation is simply amazing).
More to come as I progress through this rebuild.
cheers
cheers
