This might be a strange question, or just a strange problem. EXCESSIVE fuel pressure.
jfcroni
Mar 3, 2013
899
Midwest
Jim
My money is on dirt in the system, holding the needle valve from closing. Stuff was apart, dirt got in somewhere. All it takes is a microscopic bit. Been there. When everything's eventually truly clean, it will be OK.
Vac on my dual pump is on top too.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Mar 3, 2019
14
Virginia
Lester
#22
I measured 15+ psi fuel pressure before float bowel went dry from the mechanical pump. Gauge pegged at 15.
Jul 19, 2012
1,013
Tim
#23
Buy an inexpensive universal electric pump and plumb it in with rubber hose, bypassing the mechanical pump and see what happens. I did that on a hunting trip once and finished the trip. I keep it and a block off plate in the tool boxes under the seat now, just in case.
Mar 16, 2019
6
Panama City, FL
Johnny
#25
My fuel was hooked to top when I got truck back and had the same issue, fuel gushing out carb. Rebuilt carb, tried another one and same issue. From this thread I found where it said the fuel should be at the bottom and sure enough, that fixed my problem when I swapped around. Thanks to all. Now what do I do with vacuum pump not needed, converter to electric motor earlier.
Blindmelon
Aug 10, 2014
1,336
Agua Dulce, CA
Larry
#28
On the vacuum ports, leave them open or hook them together.. Don't just plug them..
Mar 3, 2019
14
Virginia
Lester
#30
I did this, because I'm still assessing the condition of the rest of the Wagon before I start spending a lot of money on stuff before I know what else is wrong. I'll probibly order two rebuild kits, and rebuild my spare as well.
Jun 6, 2017
94
woodstock GA
#31
I believe the rebuild kits from Walck's are only for the original Carter dual action fuel pump. Will not work with replacement pump by AC. I could be wrong so check with Walck's.
