farmersjeepster
I have a 1950 jeepster with orginial gauges. Since this was a off frame restoration all the gauges were clean and checked. Since someone had added axilary gauges with capillary tubes I also installed a new temp sending unit so I could use the original temp gauge. The Unit was bought from a reputable vendor. All the
gauges are working correctly except the temp. The gauge registers hot after a few minutes of running but I have checked the engine temperature and it is running at a proper temperature. I tested the temp gauge with a 4.7 volt power source and a variable resistor. Here are the results:
Zero resistance the gauge read hot or 100%
10 ohm resistor ... gauge 75% towards hot(to right)
20 ohm resistor... gauge read 48% towards hot
30 ohm resistor... gauge reads 25% towards hot
Does anyone know if the gauge is correct?
Suggestions PLEASE!!!!!
