Tall Motor Mounts for 226?
Jackalope
Jan 27, 2014
195
Osage, WY
Jared
A while back, I purchased some replacement motor mounts from KW when I rebuilt my 226 engine in my '58 pickup. When I replaced the mounts, I noticed that the new ones are taller than the old ones. Now my engine is higher in the front, and is causing some interesting issues. My ground strap is tight (not good), and the cylinder head is nearly touching the firewall. This doesn't seem right to me. Has anyone else had this issue? Are there shorter mounts I can use? Thanks!
Jackalope
Jan 27, 2014
195
Osage, WY
Jared
I haven't checked that out yet. The transmission is the next part of the rebuild plan. I imagine that it has never been replaced. Thanks for the thought, I'll need to take a peek and see, if there isn't too much dirt and gunk to tell. ;)
shade
Jan 25, 2013
320
Montrose, Colorado
Adrian
I found that the mounts for my 226 were different than he ones on my 4cyl. think the 6 cyl are shorter.
Oct 2, 2011
4,799
Wrentham Ma.
I have never head of that problem. Old motor mounts get soft , weak and shrink down. A lot in some cases. I do know that the rear crossmembers are different between 4 and 6, and height is part of it.
Big Dog Frank
Feb 12, 2016
1,997
North Lawrence,Ohio
Frank
Greg,some of the parts that are being sold just don't fit or work. If it ain't right the vendor should make it right. Case in point,I just bought a Scat shifter for a Volkswagen. Scat is name brand stuff. The shifter worked just fine if you never had the need to use reverse. Vw has a reverse lock out on the shifter. The Scat shifter did not have the necessary slot machined in it so it would go into reverse. Back to the dealer it went. Oh and by the way the VW guys are having issues with junk condensers also. Just like we are.
Jackalope
Jan 27, 2014
195
Osage, WY
Jared
Hmm... interesting. What is the height of the front mounts that you all have (from the mounting base to the top of the rubber)? That might help me determine if I need to find something different.
The other thing that makes me wonder is that my fan is not centered in the shroud. Not a clearance issue, but it would make sense that the original design put the fan somewhat close to the center. Thanks everyone!
Oct 2, 2011
4,799
Wrentham Ma.
Did you check the rubber bushings under the grille? body mounts?
Oct 2, 2011
4,799
Wrentham Ma.
I don't doubt you Frank, not at all. But I question just how much off a new motor mount would have to be to create a problem like that. And I said I never heard of 4 and 6 motor mounts being different. They look the same. With all the Jeep work I've done I've never noticed a difference. I COULD be wrong however. We'll just see how this works out.
shade
Jan 25, 2013
320
Montrose, Colorado
Adrian
I think I got my mounts from Willys America and they asked me if they were for a 4 cylinder or a six. Those guys are really about the best for straight info in my opinion. Carl at Walcks does a great job too but I got the restoration/parts manual from Willys America and it has been a really good resource. There are different part numbers for the motor mounts on the L6-226 Super Hurricane and the F4-134.
Jackalope
Jan 27, 2014
195
Osage, WY
Jared
How squished down is the rear mount?
Here's some thoughts of mine: The body mounts shouldn't make a difference as the engine is mounted to the crossmember in front (I'm going off memory here). The transmission mount in the rear shouldn't affect the ground strap being tight in the front as they are in the same plane as the front mounts.
From looking at the pics in KW, Walcks, and Willys America websites, the F-134 mounts being sold are shorter than the L-226. Also, the 2-piece transmission mounts appear to be the same as what is being sold for the front engine mounts (the ones I got).
I'll try to get some pics here sometime. Won't be able to get to my Jeep for a while. Thanks all!
david0225
Aug 4, 2013
470
Pittsburgh, PA
David
My 226 mount height. No issues with height or pulling ground straps before I pulled it all apart.
Jackalope
Jan 27, 2014
195
Osage, WY
Jared
I was finally able to work on my pickup a little more (you know, virus restrictions and all). I did notice that my fan was centered in the shroud after all. Also, on another post, I noticed that someone mounted their ground strap to the motor mount bolt that attaches to the frame. This made the strap very flexible. Mine strap goes all the way to the bottom of the frame crossmember by the fender. Where do you mount the frame end of your ground strap?
david0225
Aug 4, 2013
470
Pittsburgh, PA
David
57CC548E-6AD1-4752-BF5C-236887CD3B09.jpegNot a great pic but, if you look behind the alternator, you can see the ground strap going from the block to the bolt at the back of the mount.
David
