Swing out tire mount
Mrbub
Jan 24, 2022
64
Az
Brian
I have 16x10.5x33 tires on my Wagon. I mocked up mounting it in the stock location but if I did this I wouldn't be able to install a back seat, which I want to do. I ended up fabricating a new rear bumper and a swing out mount for the tire. It came out pretty nice and eorks well. Here are some pictures of the process.
What would you charge to fab up another? Other folks could be interested... jus' sayin'
I'd be happy to fabricate more of these. The main issue is mounting to the frame. I have done a 3" body lift so the brackets that mount to the frame (bolt on, not welded to frame) clear the body. I'd need measurements off a stock setup the modify the mounts. Also in a stock environment, the tire would sit higher. On my wagon I can still open the top 1/2 of the tail gate with the tire latched in place I don't think that would be true on a stock setup. You would have to swing out the tire to open the upper half. No big deal just a point of note. To answer your question to make more of these would run between $1200-$1500 complete. The features are: bumper, 3"x4"x67" 3/16" rectangle square tube, with spindle for swing out, d-ring mounts and d-rings, license plate frame with light, and 2" reciever for trailer hitch. The frame, also all 3/16" wall square tube, for the actual tire mount has a multi wheel bolt pattern to support different axles (I'm using Scout II axles). If someone is running larger diameter tires, I can raise the tire mount to accommodate that. I painted mine but I can also get it powder coated if desired for an additional $250-$275. And of course shipping would be on top of this. Thanks for asking the question, if anyone is interested let me know.
Brian,
That looks great, I drew up a setup like yours for my Wagon.
Checkout WILCO Offroad.com they have a setup like yours.
Thanks, I've been driving around with my spare just laying in the back, if I ever got in a wreck the tire flying around would probably kill me ;-) Decided to build the bumper and the mount so I can put a back seat in, so I can carry more than two people in it. Did you build one for yourself? If 3-5 people wanted one I could make them cheaper.
Nice job, looks good.
I did a 3" square tube bumper for my wagon and used the latch and parts from an Olds Bravada/Chevy Blazer tire carrier. I used bronze bushings for the pivot with a grease fitting, and the weight is carried on a clutch throw out bearing. You can't see it in the picture, but I used a Dryer Drum Wheel under the center of the wheel with a slight ramp on the bumper to help support the weight of the giant tire and rim. Been going for 6 years with a 35x12.50 18 MT hanging on it.
That came out really nice! I bought the spindle and the latch from Ruff Stuff. Does yours mount in the stock bumper holes on the frame?
I think I sold my original rusty/pitted plate mount and light on eBay for more than the tire and swing frame combined.
The 3" square tube bumper is bolted to the stock 3 bolt frame mounting. You can see it in the 3rd picture on my build page.
Yep, the original lights bring in some $$$ no matter what condition.
Ah, I didn't know that it flipped up. My Wagon never had the stock plate on it, thanks.
They flip (or down) so you can drive with the tailgate down and still have the plate showing. These would have been stock from 1951 up.
Someone had already modified my tailgate when I got it. I didn't know the license plate was hinged but that is a really cool feature.
I eliminated my tailgate plate mount and opted for the spare mounted plate and third brake light. I do like Rocket's idea for under tire support to keep it from shaking. I'll post a picture when things are up and running again. By the way what are those flip down plate holders worth I was going to list mine on Ebay20231123_111019[4059].jpg
I set the latch up so that it pulls at an angle. It pulls both down and back into the latch point on the bumper. I also used some 1/8" hard rubber material to line the mating surface of the latch point. When latched there is no downward force on the spindle, meaning the weight of the tire/frame assemble isn't hanging from the spindle, it's evenly supported between the latch point and the spindle. As a test I drove for about 8 miles on a badly washed boarded road with someone following me. No motion or vibration from the mounted tire/frame and the latch didn't budge. It did however, almost rattle me teeth out ;-)
An update to my swing out tire mount. I have a bumper jack that I've been hauling around in the back of my wagon. I finally made a mount for it on the swing out. Check it out. I also made the foot of the jack removable so it wouldn't rattle(not shown). Still working on securing the jack head so it won't rattle but I think I have a solution for that as well.
