Seat position/leg room difference between CJ3A and CJ3B?
ndnchf
Sep 27, 2017
53
Virginia
New guy here trying educate myself on the minor differences between models. I know the CJ3A has a little more leg room from the CJ2A. But is there any difference between the CJ3A and CJ3B leg room? Thanks. Steve
donthedickens
Mar 10, 2014
79
Southeastern, NC
Don
I don't think there is any leg room difference between the 3A and the 3B. The cowl was extended up and the hood is taller to allow for the F134 engine.
If you're looking for more leg room some folks have notched the wheel well and lengthened the seat bottom.
ndnchf
Sep 27, 2017
53
Virginia
Thanks. I've seen some discussions on notching the wheel wells to allow the seat to be moved back, it's a good, if not drastic change if needed. I'm 6'0, about 235 - not huge, but not small either. I think a CJ2A might be a bit tight, but a 3A or 3B would be a better fit. Trying to decide what to look for. Thanks
donthedickens
Mar 10, 2014
79
Southeastern, NC
Don
Gear Grinder,
I also am 6 foot and 225 pounds. I fit fairly well in my 53 CJ3B. When I repaired my seats I used 3 inch firm foam on the seat and 2 inch firm foam for the back.
It seems to allow plenty of room for my gut.
If you get a chance to sit in a 3B I hope you like it.
Willys49Willys
Oct 13, 2023
55
Centralia, WA
Mike
What exactly is different from the 2A to the 3A that gives it more leg room. Was the rear wheel well shorter allowing the seat to go back further? I never understood the difference. I now own a 3A and previously a 3B. Never a 2A so just curious.
scramboleer
Super Moderator
Aug 16, 2011
11,720
San Francisco, California
Dan
Curious to the answer to the CJ2A versus CJ3A question too.
Aside: here’s a 6’ 6.5” guy in a GPW tub:
Dad redid the seats a few years ago. They are comfy and overstuffed, but take up more volume than stock:
Willys49Willys
Oct 13, 2023
55
Centralia, WA
Mike
Nice Jeep!
Did some more research and it's the rear wheel tubs that are shorter by about 3". I think that's it besides the seat frame change to take advantage of the extra room but will wait for the expert's to reply.
LarrySr.
Feb 4, 2023
48
East TN
Larry
At 6' 230 I have the same issue with my M-38. I have tried what's being recommend. Still would like a wee bit more room.
Does anyone have any feed back about this recently out by Willys?
Smaller Profile Black Steering Wheel (for 1-1/4 horn button)
Fits 46-64 CJ-2A, 3A, 3B, 5, M38, M38A1, FC-150, FC-170
15" smaller profile steering wheel with 36 splines and .853" spline outside diameter.
Need more leg room or even belly room? This will help alot. This is a smaller diameter steering wheel than the original 17" and is offset/angled up spokes to give even more leg room around the ring.
Oldpappy
Sep 23, 2023
131
East Tennessee
Andrew
  2. 1947
Willys Overland has been out of business for many years, so there is not anything recently out from Willys.
I am 6' 1" and weigh about 225-230. I have no problem with leg room in my CJ2A Jeeps, but would like a little more belly room. On one of my CJ2As I used a later model steering gear with a longer column/shaft. As odd as it may sound this actually helped by raising the steering wheel up higher. I also gained a little more room by using thinner cushions on the seat backs.
Blue Duck
Mar 16, 2020
1,023
Western Texas
Stan
This will give a little more room. On the 48 2A I have now I used an old hub and grafted a 15” steering wheel on to it. It makes more difference than you would think, but also some lose of leverage when steering.
timd32
Jan 4, 2020
5,181
NJ
Tim
The trucks are not much better. Won't work for everyone, in my direct case, some diet and exercise would probably be the fastest way to more room between me and the steering wheel.
Good luck going into Holiday season with that.
Blue Duck
Mar 16, 2020
1,023
Western Texas
Stan
The legroom/ belly clearance is an on-going question. Here is a link to to a simple solution that I did a few years ago on a 2A. Anyone with even minimal welding skills can do it, only involves cutting the seat frame as opposed to chopping out the wheel well. And you can still enjoy thanksgiving dinner!
LarrySr.
Feb 4, 2023
48
East TN
Larry
It was supposed to be at Kaiser Willy's that has the new smaller steering wheel.
