One more project as I'm waiting on my engine at the machine shop...decided I've had enough of the floppy brake pedal--had bought new parts (brake & pedal cross shaft and tube bracket) a while back, but never got around to installing them (clutch arm is ok, still need to buy a new brake arm). I tried just the shaft (using the old tube as it was riveted (and welded) and I didn't want to mess with it) but there was still more play than I liked...
So this morning I decided to get the tube bracket off and replace everything.
I thought (!) I could just grind off the head of the rivets and the use a punch to drift them out.
Wrong.
I ended up griding out the old tube, then grinding out the leftover "ears" that were welded to the frame (what a chore). What I ended up with is the rivets now sticking out of the frame about 1/4 inch, and I can't get them to budge.
Decided to drill them out--broke one drill
(but got it out). Eventually got tired enough that I called it quits at 1/4". Have quite a bit more to drill out...
Yet there's got to be an easier way (I may try pressing them out tomorrow with a big C clamp...)
Wondering if anyone has any tricks to getting these out? I would normally consider heating them (and I may try that a bit tomorrow) but I have electric wires, brake lines, and fuel hose running right through that area...
Any ideas? Soaking them with PB Blaster right now, hoping I can loosen them up a bit without having to drill them all the way out--working under the car to do this is a bit of a PITA...
Appreciate any ideas from folks that have done this...
d
Wrong.
d
