problems mating T-90 to Dana 18
Corker
May 31, 2022
46
Washington
Vaughn
I got around to finishing the rebuild on my d18 transfer case, and was trying to get it mounted back on the transmission and I am running into a problem. They are both on the workbench and when I go to tighten the bolts to mate the two together, I have a really tough time getting the machined surfaces to squeeze the gasket. The real problem though is that as I tighten the bolts, I cannot turn the input shaft at all. It goes from easy spinning to locked up tight with half a turn of a bolt. It spins smooth and free when the transmission is all by itself, and when I first get the rear bearing slid into the transfer case as well. As I get the bolts about 80% in, it seizes up.
I think what is happening is that the rear bearing is forcing the transmission output shaft into the roller bearings on the input shaft, with enough pressure that it is preventing things from turning. Maybe because the new bearing is wider than the original? Anybody else experience anything like this, and what did you do? My only thought is shim it in some way, or maybe try another rear bearing. Wish I would have kept the original now.
Transmission was torn down and the bearings all replaced, but all the gears and case are the same. Same thing for the transfer case. It's the same case that was mated up to this same transmission with only seals and an intermediate shaft replaced. These were spinning fine together when I tore them apart, but with this rig having not ran in 10 years or so, I had to tear them apart to see if they were even serviceable.
In the tail of the input shaft there are 13 rollers which are the bearing between the shafts. Check and make sure one did not drop out of place and is now setting in front of the hole preventing the main shaft from going all the way in.
I had to do a little extra tapping to get the lock plate down in the right position, to at least clear the gasket. I cant quite see if it is interfering though. I'll have to check again later tonight.
I keep checking this, and am pretty confident that hasn't happened. I was having difficulty getting the second gear syncro to fully engage the gear and thought that might be the case then, so I've pulled the main shaft assembly like 4 or 5 times and reset the needle rollers. If I can't figure this out though, I'll take it off again.
Is the rear roller bearing seated on the tail of the main shaft all the way? Is the spacer too wide? Is the spacer in the right position? Are the synchros nested properly? Is the input shaft seated fully forward in its bearing? Is the c-clip in front of the 2nd gear fully seated in the groove on the main shaft?
Pretty sure I figured out what it is. I measured the thickness of the rear bearing and then the depth of the slot that it fits into on the transfer case. The new rear bearing is 1/8 too thick, so I have the wrong size. It is seated all way against the spacer and the main shaft retainer so it is completely bottomed out.
When I ordered the replacement bearings I got sealed bearings and I'm wondering if I ended up getting 2 front bearings by mistake. I can't find the dimensions on any of the sites with a quick search, but they all list front and rear bearings separately, so there must be some difference. I hope I didn't mess things up trying to crank it down.
Anybody have dimensions on the front and rear bearings?
The front is a 208 size with a snap ring groove and the rear is a 307 size.
This is why I love this forum, fast meaningful information from great willys owners!
Well crap, I think I do have the correct bearings then. I did pull it apart again, leaving only the reverse idler gear in place, and double checked to make sure i didn't miss something, and though I thought it was bottoming out on the bearing retainer plate, now it would appear the bearing spacer sits proud. With the bearing pulled off, I also remeasured the total space from the retainer plate to back of the bearing cap on the transfer case, and....the bearing fits just fine.
I pulled the pilot bearings from the input shaft since it was all pulled apart anyway to see if maybe something else was blocking it, and even with a bare mainshaft and no pilot bearings, the rear bearing spacer still protrudes.
Any ideas out there? I'm thinking about milling the spacer down, trying to find a thinner spacer, maybe new mainshaft, but I don't know. I'm also going to have to spend some time figuring out a second gear problem but I'll save that for another thread.
Isn't there 1 or more? shorter bolts, if a long 1 is used, don't remember where, it can
go against a gear and lock it up.
Something is definitely amiss. That bearing support piece should sit flush. Do you have the snap ring on the input shaft in front of the input bearing? Do you have the snap ring on the outer side of the input bearing?
Do you have all of the synchro dogs aligned into the slots of the synchronizer rings?
Yes on all three. The snap rings are all
in place including the one holding second gear in the correct location, and I thought maybe the pawls we’re not lining up too, but I’ve quadruple checked that they are in there correctly.
Funny enough too, when I put the shift tower on, put it in 2nd, then pull the tower back off, the sleeve is short of meshing fully with 2nd gear by almost exactly the same amount as that spacer sticks out.
I need a new dial caliper, dropped and broke my other one, so maybe I’ll pick up a new one and post some measurements. That might narrow things down if folks have some stuff to compare it against.
Yes, a too long bolt can jam against the reverse idler, but it doen’t sound like that’s the issue here.
I’ll try to remember that when I can get it back together. I think all my bolts are the same length. I know there is one on the front output of the transfer case that can do this.
Damn it Corker you are not being very helpful in solving this! LOL
You have got me stumped. Are you using the same input shaft, main shaft and tranny case? I'm just searching for variables.............
I think being a pain the ass is just part of my nature;)
Same main shaft, same input shaft, same case, same synchro hub. The only parts replaced on the entire transmission are all of the bearings, blocking rings, and gaskets.
