new project - Willys truck rolling chassis - how to ID?
smaj100
10
tn
lee
New poster looking for some pointers. I want to start a Project truck. Ive found a rolling chassis but can't id the year on the engine or frame. Can you guys help? No metal data plate can be found on the frame.
Eurodoublecab
15
Santa Claus,IN
Ive been watching this frame& Engine. The guy says ‘60ish, but it’s probably a late ‘62. I just bought a ‘62 pickup North of Nashville. It has the Tornado 230 engine in it. like the one you're looking at. I was going to check it out the next time I visit my daughter in Knoxville.
Gojeep
Jan 10, 2010
3,725
Victoria Australia
Marcus
Picture of the front cross member will let us know if it is at least a 4 or later 6 cylinder chassis. Also there will also be a number stamped on the chassis rail. Often near the front shock mount or even right near the back between the bump stop and rear shackle from memory.
smaj100
10
tn
lee
any suggestions on the serial number 453 EC2? I get 53 is the year built, does the ec2 and 4 stand for anything specific?
smaj100
10
tn
lee
oh, ok. sorry
No problem. I didn't want to start a new thread just asking for additional info. This is on another cab, was just wondering if the EC2 really stood for anything. 1st 3 digits are 453 assumed the 53 meant year, don't know about the 4 either.
smaj100
10
tn
lee
Ok more questions . How can i tell if a truck is 6v or 12v with no battery installed? Don't want to fry anything trying to jump start it.
Larry Messing
Apr 5, 2014
2,240
Phoenix AZ
Larry
Ok ....
The 453....
4 cylinder....1953....
EC2.. simply.Indicates you have a 475 pickup...
This should be followed by a 5 or 6 digit production number....Willys numbers started at. 10,001 .....
so for instance... My truck data plate reads ...451 EC1...19601..
. Which simply indicates I have a 4 cylinder 1951 pickup that was the 9, 601...truck off the assembly line...
There were different abbreviations for different types of configured.vehicles....EB.....EC....ED.....EE.....EF.....
..here is a partial list I found in regards to your 53 truck
475-4WD Chassis and Cab
475-4WD Pickup
475 Platform Stake
475-4WD Chassis, Cowl and Windshield
475-4WD Chassis Flat Face Cowl​
453-EB2-10001 and up
453-EC2-10001 and up
453-ED2-10001 and up
453-EE2-10001 and up
453-EF2-10001 and up
Hope this of some help to ya....!!
Larry
smaj100
10
tn
lee
Ok ....
The 453....
475-4WD Pickup
475 Platform Stake
453-EF2-10001 and up​
Larry
Thanks Larry. Going to look tomm and hopefully bring her home.
Lee
Ken_Parkman
Oct 28, 2013
380
Ontario
Ken
In the picture the block casting code is L24, which is Dec 2 1964. That is probably after the trucks completed production, so it is *probably* a service replacement engine (maybe factory warrantee?) in early 65.
Herk
Dec 24, 2011
711
Boise, ID
Nate
Frame should be stamped on the right side just ahead of the front shock mount.
scramboleer
Super Moderator
Aug 16, 2011
8,257
San Francisco, California
Dan
Willys America sells a great technical guide to the Tornado. Also there are service bulletins in the OWF library.
Plus there are some excellent Tornado experts here on the forum, like @Ken_Parkman and @cwdtmmrs among others.
Save the Tornados!
PS. You may also have the upgraded steering.
kghills
14
Brooklyn, WI
Keith
Save the Tornados!
Thank you for the heads up on the steering. I was unaware there were changes. My plan is to use this engine and running gear in a 51 wagon I recently purchased. As luck may have it the steering on the 51 was removed so I was planning on using the components from the newer truck along with the Tornado, wide ratio trans and transfer case 9A345E63-6317-4244-B95B-10EC07545B85.jpeg
Ken_Parkman
Oct 28, 2013
380
Ontario
Ken
Differences that I'm aware with the Tornado compared to a 226:
  1. Gear ratios in the wagon should be 3:54, optional 4.09/4.10
  2. Steering box is reversed to go with the bell crank steering.
  3. Bell crank is mounted with a tube welded into the front crossmember, and link goes to passenger side with a tie rod back to the drivers side, greatly reduces the earlier bump steer geometry and improves the stability.
  4. Should have a little bigger bearings and seals in the front wheel hubs. It's still a Spicer 25, this was a running improvement at some point; some of the vendors have this wrong.
  5. Engine mounts are different.
  6. There is a small slice out of the front crossmember to allow removal of the oil pump with the engine installed.
  7. There is a big cutout and replacement box section in the firewall to clear the bigger head.
  8. Battery is mounted different on the driver’s side.
  9. Different heater with vacuum controls.
  10. Other more minor stuff.
I'm using an earlier truck frame (pretty decent) on my Tornado pickup cause the original is so rotted.
