Noticed that. They look to be quite a bit larger than the normal .125" holes also. Those look to be at least a .281" or 9/32.Saw the small hole at 6oclock. Never saw wheels with the small hole there and that threw me. Most of the small holes are at 3 or 9 oclock. Thanks
Hey Edwin...
Ok what you need to do is to clean them up a bit and then look to see if the wheels are stamped with a small KH somewhere on the face of them......
......that will then tell you if they are the original Kelsey Hayes wheels or not that came from the factory on Willys Trucks and Wagons.
9
Larry
Mine are now tubeless with bfg km3 mud terrain tires. A perfect fit so far.I noticed they have valve stems should they be tube type just asking
@Afootorafloat, what size tires did you go with?Mine are now tubeless with bfg km3 mud terrain tires. A perfect fit so far.
