How about electric power steering?
duke94
Sep 17, 2014
929
Ann Arbor, MI
Gary
#61
Here's a decent write-up on the EPS. Apprently they use BLDC motors...similar to steppers, but many less steps per revolution. I was looking at these a year ago, but lost interest at $2000 bucks.
https://www.knowyourparts.com/technical-resources/electrical/electronic-power-steering/
Thanks for this. The question I have is how does the motor worm gear de-couple from the steering shaft gear if the motor fails? The gear on the steering shaft can't turn the worm, can it?
jfcroni
Mar 3, 2013
899
Midwest
Jim
I haven't been able to glean any data regarding fail-safe mode... but it looks like you'd be able to overcome the motor through the worm gear if no power was supplied to the motor... but I'm still researching. Here's another EPS maker in UK.
http://litesteer.com/fitting/self-fitting/
captainlance
Jul 22, 2017
688
Long Island, New York
Lance
#63
I asked that question when speaking to the factory rep. She said it reverts exactly to what you had before, effort-wise.
duke94
Sep 17, 2014
929
Ann Arbor, MI
Gary
#67
OK, now the fun begins! Unit arrived today.
First impressions:
> looks like a quality piece, no cheap plastic parts.
> Uses GM Weatherpack connector
>No instructions included, but a video is on their website.
>Wiring seems to be plug and play. Run a power feed and ground rest is pre-wired connectors.
>You can turn the shaft easily by hand so if the unit fails, it's just normal steering.
>There are 2 couplers one at each end that will have to be welded to the shaft.
>The shaft thru the center of the unit is not hollow, so horn wire needs to be rerouted somehow.
Bill Kuran
Oct 14, 2009
699
Potomac, MD
Bill
#69
That does look nice. Since I modify most things I buy, first thing would be a visit to a gun smith to drill a 1/16" (or so) for a 22 AWG horn wire.
duke94
Sep 17, 2014
929
Ann Arbor, MI
Gary
#70
Don't be jealous until after WE make it work. I've already checked with Jo Sheets at Midwest Willys to be sure they have a good used column in case this is a bust. But, in eyeing the thing up, as long as I cut the shaft and tube the right length (measure 20 times, cut once!) it seems fairly simple.
Pointy Grille
Aug 29, 2018
260
Silverado, CA
Bob
#71
I'm seeing what looks like an exit hole drilled into the upper column coupler, most likely for the horn wire. Prolly better than having that pesky horn wire coming up from the depths of Ross box hell :) Of course it keeps the brake switch wiring company.
Really looking forward to the next installment of this story.
cwdtmmrs
Jul 19, 2012
1,013
Tim
#72
What are the dimensions? The motor looks like maybe 10" x 3" and you need to cut 10" out of the middle of the existing steering gear.
Igotthewillys
Feb 23, 2014
151
United States
John
Other
#73
First impressions:
View attachment 57638 View attachment 57639 View attachment 57640
Awesome. Glad you spent your money first
duke94
Sep 17, 2014
929
Ann Arbor, MI
Gary
#74
The length from one end to the other (the sleeves the tube goes in) is 8.75". The tubes go into the sleeve about 1" so about 6.5" will need to be removed from the tube, more from the shaft. I'll be more precise as I get more into it. P1070255.JPG P1070256.JPG
jfcroni
Mar 3, 2013
899
Midwest
Jim
I'm about ten minutes from buying one of these myself. Keep us posted Gary!
duke94
Sep 17, 2014
929
Ann Arbor, MI
Gary
#80
Made some progress today. I've mocked up the tubes and shaft using a piece of conduit and another tube. I have the tube lengths correct. Gotta say I'm a little nervous about cutting the shaft. I was a little off on the lower tube dimension so don't use what I have on the sketch above. It looks like it will fit under the dash rather nicely, but I think it will need some sort of support bracket to hold the motor to the dash. So far so good. P1070268.JPG P1070269.JPG
