Help Identifying Family Willys Jeep - Possible CJ2A/CJ3A/MB-GPW Jeep Salad
jd_abramson
May 18, 2026
10
Tennessee
Joshua
Hello everyone,
I’m starting a new thread in the CJ section to help identify my family Willys Jeep and get guidance before I begin restoration. It has been in my family since the 1960s, and I recently acquired it.
Thanks to everyone who welcomed me in the intro thread. Also, JABJEEP , I liked the “Jeep salad” comment. LOL. That may be exactly what this is.
Based on the feedback so far, it may be a mix of parts. The glove box door appears to point toward an MB/GPW body tub, while the semi-floating rear axle, grille, and rear shocks seem more CJ, possibly CJ2A or CJ3A. I have not found a frame stamp yet, but I am still looking.
I’ve included pictures and measurements and would appreciate help identifying:
  • Possible model/year
  • Body, frame, axle, and drivetrain clues
  • Where to look for serial numbers or casting/stamp marks
  • What appears original versus swapped
  • What to inspect first before driving or ordering parts
  • My early priorities are brakes, differential/axle seals, fluids, steering, suspension, wheel bearings, and general safety items.
Thanks in advance. I appreciate the help and look forward to learning more as I work through this Jeep.
Looks like a CJ2A with a Ford GPW body tub and front axle. I replaced a rusted out CJ3A tub with a GPW body tub, so it's not hard to do. The Model 41 rear axle and frame indicate CJ2A rather than MB/GPW or CJ3A. It has a spring over axle lift and fewer, flatter leaf springs, and many other modifications. But the front axle appears to be an MB/GPW axle (steering pivot on the axle tube) with CJ parts from the knuckles out (cast-in arms, not bolt-on). It's a jeep salad, and buying parts will always take some research. I suggest keeping a list in the glove compartment explaining what's what as you figure it out.
Mostly cj-2a, as said ford body tub, mb hood, 2a grill and fenders, 2a seats, post war engine, 41 rear (2a) 25 front (not mb/gpw) 2a wind shield (mod to 1 pc glass) 2a wheels... And someone liked the spare on the hood like a land rover, ( bad idea bends the hood and hits the ws when up if you can lift the hood up)...Phil
Thanks for the help so far. I wanted to start a CJ thread to document this Jeep and figure out what components I actually have before ordering parts.
Based on the latest feedback, it sounds like this is likely a CJ2A-based Jeep with a Ford GPW/MB-style body tub and several mixed components. JABJEEP’s “Jeep salad” description seems pretty accurate..
Here is what I understand so far:
  • Body tub: likely Ford GPW/MB style due to the glove box door shape. The floor pan is in terrible shape, and I'll likely replace the whole body.
  • Frame/rear axle: likely CJ2A, with the Model 41 rear axle pointing away from MB/GPW and CJ3A.
  • Front axle: now appears to be a Dana/Spicer 25 front axle, possibly with mixed military/CJ components from the knuckles out.
  • Suspension: modified with a spring-over-axle lift and fewer/flatter leaf springs.
  • Engine: appears to be a Willys L-head/Go Devil style engine. The block is marked WILLYS, and the casting shows the firing order and tappet clearance information. I am still trying to locate the engine serial number.
I have not found a frame stamp yet, but I am still looking:
  • Front and rear axle details
  • Engine, transmission, and transfer case identification
My goal is to make a running list of what this Jeep actually has before buying parts. Early priorities are brakes, axle/differential seals, fluids, steering, suspension, wheel bearings, and general safety items.
Do you have a title or other paperwork? That might help figure out if is was an MB or CJ to start with. It's a toss up,(salad joke).
Spicer 44 rear, NOT 41. The butchered frame in front is unidentifiable. I’d get any VIN tag (MB, CJ2A, 3A) and go for it. I hope you have a T90 CJ trans The MB T84 is a POS. What you probably have is an MB body on a CJ3A frame.
That being said, it’s so hacked that it makes no difference what it is.
Does the 44 come with a round lid? I have only seen 41 with the round cover...Phil
