Fuel tank fill pipe
Truckedup
Jul 11, 2010
289
Western NY state 315 er
I have a 51 Willys pu with no fuel tank.I read the post on the plastic tank and it seems the best bet considering the "reasonable" price.What about a fill neck? What size is the gas tank opening OD? Probably can make something from a piece of steel tube and weld on a end from an older PU truck so the gas cap can twist on.Any other ideas that worked for you? Thanks
pavel6
Sep 27, 2009
1,864
Vancouver, BC
Pavel
If you have a stock engine/carb/fuel line, your best bet might be to contact Willys America or Walcks to get the correct used part. If you will be using a modern fuel system (with return line to the tank and vent, then you might be better off going to the wrecking yard and pulling a newer design filler tube which has the integral vent.
