Nomadr
I am looking for info on the front engine mounting plate for a 1948 Jeepster with an L-141. Specifically, which way the motor mount ears should point.
My Jeepster came with an F-head. I am swapping out to an L-head. I have a couple of engine plates around from various parts I have acquired. The F-head that was installed had a mounting plate that had the motor mount "ears" pointing forward. I used this same plate on the L-141, and it seems that it is pushing the engine too far back in the engine bay. The rear of the engine is very close to the firewall, the clutch linkage is cramped, and it just doesn't seem right.
I have a mounting plate with the ears pointing back, but I am not sure if it is correct for the Jeepster. What is the correct mounting plate? Can one from a 2WD wagon or pickup be used?
Here is the current setup.
Thanks!
Thanks!
