jimz49
I saw the following posted on willystech.com:
I used a GM HEI in my '60 226. If you don't have a problem with so-called originality, the multiple spark of HEI makes a flathead run and start like nothing you've ever seen. The easiest conversion for a 226 is to get the HEI from a Chevy 292 straight six. Use the old distributor adapter and drive key. Saw off the GM shaft to the correct length and pin the drive key on. (shaft is same size as old one) Drill and tap the old adapter housing for a set screw. Replace the adapter on the block, slide the distributor into the adapter (I forgot to mention that it is a perfect fit) and plug the coil wire into the distributor. Set the timing and you are in business. You now have a 226 with a new personality. I have done similar conversions on 134's but you need to do some machining. These use HEI from a Chevette or other 4 cyl.
Has anyone done this and do you have pictures? I would like to see what this looks like. As they say a picture is worth a thousand words. I'm having a difficult time determining what is being sawed off and what the correct length is.
