Willy48
Was going to post this in the Weekend update section, but this is more of a rant than a "Hey lookit!!"Time to convert my wipers from vacuum to electric. Took off my vacuum motor and disconnected the slide cable/rotary switch, which was easy. Took my brand spankin new electric motor from Walck's (after a three month wait), lined up the rotary propellor with the wiper socket, marked where I had to put in my nutserts, drilled the firewall(a real pitty as the sheet metal is nice and painted), put in the nutserts. Hey this is easy!! Mounted the motor, ran the new wires, put in the new switch above the ash tray (doesn't quite fit) , stood back and looked at the installation and thought, "Kool". But the more I looked, the more I didn't like the way the motor gearbox was sitting higher than the motor. Then I went to close the hood. NOT.....!! The cross-brace on the rear of the hood became VERY intimate with that gear box while the hood still had 8" to go before being closed. Tried turning the motor assy 180* but this put the mount way above the hood line. Seeing as how the "propellor" is pinned to the motor shaft, it's parked location is not changeable and all that would do is relocate the mount in an unfavorable location again. Man, I'm ripped :evil: I should have known that things would not be quite right when I removed the unit from the shipping box and the instruction sheet was a hand-drawn schematic that had been copied so many times it was almost illegible. I guess the old addage of "Buyer Beware" holds true once again
Anyone out there do an electrical motor conversion and have it come out correctly the first time? I'm gonna give Newport Engineering a shot. Used their product in my '54 Ford sedan and was very pleased
Later...
Lee
Later...
Lee
