Spent some time trying to get my passenger door working this weekend. The outside door handle was missing the trigger, so I replaced it with a used ebay handle. The used handle had quite a bit of wear too, and wouldn't push the trigger inside the door far enough to open the latch. I added a small machine screw to the little part that pushes the lever inside the door, and got to working fine.
Once I had the handle working, I got to looking at the striker plates on the door jambs, and I think they are on backwards. Looks like the dumb-ass PO swapped them side to side when he had them off to paint the door jambs.
Is the little spring loaded bit supposed to be on the top? Mine don't touch anything when the door is closed...
And the latch seems to only latch onto the first click. Shouldn't the latch rotate to the second click when the door is shut tight?
Also noticed that the hinge pockets are stretched out from opening the doors too far (door stops are missing). The passenger side is the worst. The edge of the spring hole is pushed out far enough that the door doesn't want to close all the way because it hits the edge of the pocket. The new rubber seal that the PO put on is all chewed up from getting squished where there is no roof for it between the edge of the hinge pocket and the door.
I'm going to have to pull the doors off and see if I can hammer the pocket back into shape so the doors will close like they should.
