I’m beginning to think the company that rebuilt my L226 has installed the oil pump incorrectly. Before I started this project I numbered the distributor to match the plug wires to the cylinders and had cylinder No. 1 at about the one o'clock position. When I set the distributor on the shaft and set cylinder No. 1 to top dead center, the rotor is not lining up with where cylinder No. 1 should be. If you look at the photo below the rotor is almost to cylinder No. 4
In the second photo, I’ve turned the distributor drive shaft 180 degrees hoping that was the issue, but then the rotor lines up almost with cylinder No. 5. I know that the distributor will fit into the slot at the top of its drive shaft only one way as the slot is offset from its center.
Reading in the Willys Service Manual Section C-22, Incorrect Installation of Oil Pump; “the relationship of the oil pump driven gear to the driven gear on the camshaft is critical because it determines the relationship between distributor rotor position and piston position.” One tooth off, and the timing will be 36 degrees advanced or retarded. “With the No. 1 piston at top dead center the distributor rotor should point downward and forward at about five o’clock”.
But that’s not where I marked cylinder No. 1! Looks like its at cylinder No. 4. Downward and forward from where exactly?
Has someone experience this issue? Am I missing something here? Does anyone have a photo of their distributor and rotor at TDC for cylinder No. 1, looking down directly from the front of the engine?
It is the Auto-Lite IAT 4206B distributor I'm using.
Not looking forward to dropping the oil pan before I exhaust all other options first and see if someone can show me just what is going on with this.
