Going to post my findings as I disassemble my engine (as part of my ongoing project)...
So far so good today--nothing crazy, but a few questions:
1) I'm misisng the tube that goes from the main bearing cap into the sump. Not sure what the purpose of this is, nor if it's necessary to replace it.
If I do need it, anyone have any idea who might suppy this? And is it just a press fit, or is there some kind of a retension mechanism? (I'd be a bit worried if it's just a press fit that it could work itself loose and drop into the pan, which perhaps is why it's not there?) I also don't see this in my parts manual...
Thinking this would only serve to funnel oil from the main bearing into the sump? So if it's missing, wouldn't the oil just go into the sump anyway?
2) I measured camshaft end play at 20 thou...and spec is 4 to 7 thou...
I haven't taken the cam out yet, but the manual seems to indicate that the end play is the difference between the thickness of the spacer minus the thickness of the thrust plate. Right now, I'm thinking maybe the camshaft gear or thrust plate hasn't been tightened to spec (probably the thrust plate?).
Thrust plate: 20-26 ft lb
Camshaft gear: 30-40 ft lb
3) Cam gear and crank timing gear seem to be in good condition. Are these re-usable or is it best practice to just replace them? (Particularly the cam gear as it is some kind of composite...?)
4) I do have Pal nuts on the rod bolts. Are these even needed? If so, are they re-usable, or is it best practice to buy new ones?
Think that's all for today--going to dig in more tomorrow.
One comment is it was virtually impossible to see the timing mark on the cam pulley that matches up to the crank pulley--I had to line the gears up to where the mark should have been, and then clean and check very carefully, and finally I could see it. Maybe it's more visible on a new cam gear, but even now when I know where it is, it's nearly invisible.
