zlucky_13z
- Mar 2, 2011
- 108
- Willys Model
- Willys Year:
Hi all. New to the forum, and have a ton of questions about my rebuild. I have a lot of different avenues that I can take for this rebuild, as we all know, but I want to do it as cheap as possible. So what I would like to do is keep everything as original as possible, but upgrade just enough to achieve highway speed. I was thinking that I would like to just change the axle ratios, and put in an overdrive unit. My question though is this: What all do I need to buy in order to change the axle ratios? Do I just need the Ring and Pinion set, or is there more to it than that? And also would it be cheaper and less of a hassle in the long run to just buy a front and rear set of scout II axles? Another question is this: If I want to run say 4.09 gears in the rear, does the front axle ratio need to be the same, or can I leave it stock? Cause in all actuality the front axle would only be used for slow off road speed anyway, but I don't know if that puts undue stress on the trans/t-case running two different ratios. As much detail as you guys can give me will be appreciated. This is my first ever rebuild. I'm not a mechanic by any means, but I am mechanically inclined.
Thanks to all in advance.
