Cap'n 1950? truck
I hooked up a new ignition switch and the battery drain continues. Also the engine doesn't crank over even with a charged battery, which started before I replaced the ignition switch. Checking everything, but this is puzzling after I had just had the first "drive".
This battery, when "fully" charged shows 6.29 volts, not as high as it should be according to an Internet search. Could the battery be the cause of the drain and not an external source?
I would think that, yes, it's possible. Maybe a bad cell. Try this test; disconnect it, charge it, measure it, then measure it 24 hours later, and again 48 hours later. That should be a simple "at home" test. Or take it to Batteries Plus and let them load test it. Is it the old-fashioned type with the removable caps? You could do a hydrometer test too.
Meant tests dead cells "that" way, not "thar" way. The new battery solved the cranking problem, but I still don't know if I have a current drain. I'll check that after a few hours. Thanks all!
The new battery seems to have solved the current drain problem! I cranked and started the truck yesterday evening with the voltage at 6.37and it's still at 6.32 this morning. It took quite a bit of cranking to get him running, so I'm assuming that brought the voltage down some, and hopefully when I can run the engine longer it will charge back up. Thanks
Try the bulb test just to make sure.
If you do/did have parasites, a new battery would not exterminate them.
You can also substitute the leads of your multimeter for the bulb. If you are not typically seeing a spark when you hook up your positive cable with the key removed, it should be safe to set the multimeter for "200m" to start out.
