Ckelley254
I have a 55' wagon that has the original drum brake setup. After adjusting the front brakes, the front drivers side wheel started to lock up after braking. I re-adjusted the brakes on this wheel, removing most of the drag on the wheel from the adjusters. Everything seemed fine, but on my way home from doing some errands, the front drivers side wheel started locking up again when the breaks were applied.
I'm thinking the possible culprit could be a bad wheel cylinder, or maybe some crud in the break line. Has anyone else experienced this problem before. I will be pulling the drum off this weekend to re-inspect the brakes and wheel cylinder. (I inspected everything, and checked the shoe lining the day I adjusted the break shoes, about three weeks ago. Everything looked fine, with no leaks, ect.)
