Brake troubleshooting
Ckelley254
Mar 23, 2016
147
Severance, Colorado
Chris
#1
I have a 55' wagon that has the original drum brake setup. After adjusting the front brakes, the front drivers side wheel started to lock up after braking. I re-adjusted the brakes on this wheel, removing most of the drag on the wheel from the adjusters. Everything seemed fine, but on my way home from doing some errands, the front drivers side wheel started locking up again when the breaks were applied.
I'm thinking the possible culprit could be a bad wheel cylinder, or maybe some crud in the break line. Has anyone else experienced this problem before. I will be pulling the drum off this weekend to re-inspect the brakes and wheel cylinder. (I inspected everything, and checked the shoe lining the day I adjusted the break shoes, about three weeks ago. Everything looked fine, with no leaks, ect.)
Bill Kuran
Oct 14, 2009
752
Potomac, MD
Bill
#2
My experience with what you describe was caused by brake fluid on the lining from a leaking wheel cylinder. I put the shoes in an oven at 425°F for six hours to evaporate/burn away the fluid and replaced the wheel cylinder. Maybe take another look at the lining.
tnestell
Jun 13, 2010
558
Saginaw, Michigan
Ted
#3
I had this problem also. My fix was to shorten the push rod from the pedal to the master cylinder about 1/4". It is adjustable. When cool everything was fine, but after warming up the problem would show up.
Ckelley254
Mar 23, 2016
147
Severance, Colorado
Chris
#4
I thought about that. I fiddled with the adjusters again today, drove it, and it seemed ok. A few hours later, I went to go get my son from school, and I didn’t get 50 feet from my house before it locked up. Would it do it after sitting for that long.
jfcroni
Mar 3, 2013
950
Midwest
Jim
If all adjustments seem good.... if you have old flexible rubber brake lines from the block to the cylinder, they could be swollen internally and not be allowing the fluid to return into the lines under the spring tension between the two shoes. Could be the cylinder too.
Ckelley254
Mar 23, 2016
147
Severance, Colorado
Chris
#6
Ahh, the rubber linesp never crossed my mind. They haven’t been replaced since December 1997, so it’s probably time. Lol. I guess we’ll see when I get the wheel and drum off.
Feb 12, 2016
1,199
North Lawrence,Ohio
Frank
#7
It could also be weak return springs or improperly installed springs. I have seen them installed with the hooks in the wrong places and they will not apply enough return pressure to return the brake cylinder. Good luck and let us know what you find.
Ckelley254
Mar 23, 2016
147
Severance, Colorado
Chris
#9
Update:
Sorry it took me so long. But I only got garage time yesterday. After pulling the drum and hub off, I looked for any brake fluid and leaks around the wheel cylinder. I found none and the rubber on the wheel cylinder looks good. I did notice that the bottom return spring is a little week. I switched all of the bleeders out to the doorman one person quick bleeders and re-bled the entire brake system. I then adjusted the brakes. So far on a few test drives everything seems to be working. The fluid in the system looked pretty clean when I bled it.
I’m not sure what was causing the left front wheel to lock up, and it is probably too early to say that I fixed the problem. I will be driving to town later on this morning and I hope everything goes well with it. If the problem come back, I will know to replace the wheel cylinder and I will also replace both of the rubber brake lines for the front. I will also need to replace the adjuster’s as some are stripped out and a 5/16 wrench no longer fits on them. Also, I order new springs.
Not sure what caused my problem, only that before it started happening, I had topped off the master cylinder with brake fluid. Maybe too much and there wasn’t room for expansion once the system was warm. But I’d think it would cause the entire brake system to lock up.
Anyway I guess I’ll find out when I go to town. B4CD4483-5B1A-436E-8533-9F0649E5EF7C.jpeg B4CD4483-5B1A-436E-8533-9F0649E5EF7C.jpeg B4CD4483-5B1A-436E-8533-9F0649E5EF7C.jpeg B4CD4483-5B1A-436E-8533-9F0649E5EF7C.jpeg 029A848B-1008-467D-915F-F95EEBF46AD8.jpeg 029A848B-1008-467D-915F-F95EEBF46AD8.jpeg B4CD4483-5B1A-436E-8533-9F0649E5EF7C.jpeg AF362D0E-3DF4-4EA0-BE6E-E9F1B90265F3.jpeg C0DBD605-2B3D-42B5-B8C2-DFEC9E341EBA.jpeg 029A848B-1008-467D-915F-F95EEBF46AD8.jpeg C0DBD605-2B3D-42B5-B8C2-DFEC9E341EBA.jpeg B4CD4483-5B1A-436E-8533-9F0649E5EF7C.jpeg 029A848B-1008-467D-915F-F95EEBF46AD8.jpeg
Blindmelon
Aug 10, 2014
1,390
Agua Dulce, CA
Larry
#10
If that's the left front, the shoes are on backwards.. Long shoe on the front, short on the rear... If you switch to Bendix single anchor it's long on the rear, short one on the front
Ckelley254
Mar 23, 2016
147
Severance, Colorado
Chris
#11
Thanks for that catch. I should’ve noticed it the very first time I took it apart. It’s been that way since 2012. I paid a quack mechanic to do the breaks as I was working 80+ hours a week back then. Looks like I’m going to be pulling all my wheels and hubs to check all the other brakes now.
P.s. does the long shoes face the front on the rear, or are they the same size?
Blindmelon
Aug 10, 2014
1,390
Agua Dulce, CA
Larry
#12
Yes, front and rear brake assemblys are identical in this application.. The rear shoe has a shorter lining to equalize wear.. The front shoe would wear faster than the rear if they had the same size lining..
Blindmelon
Aug 10, 2014
1,390
Agua Dulce, CA
Larry
#13
Just another tip regarding front drum brakes... Check your front wheel bearings.. A loose bearing can make your
brakes pull...
Sep 1, 2018
174
Vallejo California
Larry
#14
Throw a Turkey in there for about 3 hours...fluid smoke maybe an interesting fusion cooking flavor...Willys meets Gobbler
Ken_Parkman
Oct 28, 2013
229
Ontario
Ken
#15
I vaguely remember once doing an adjust (drums, but not a jeep) and it caused it to grab. Then it wore in a bit and the problem solved itself. My opinion was the adjust cause the exact way the shoe hit the drum changed and caused a slightly different self energizing effect - and it grabbed until it re-seated itself. IIRC it did not take long. If there is no fluid - which for sure messes them up - I'd go out and find a "safe" place and load the shoes a bit to seat them. See if it fixes itself.
Of course if you correct the shoes that will probably exaggerate the need to re seat.
BTW I bought a complete Bendix kit assembled, installed it on Sunday. EVERYTHING is wrong, adjustors on wrong side, shoes reversed. By now if someone tells me a job I did is as good as a pro I respond... It's that bad?
56STK
Sep 26, 2010
45
If it happens again, open the bleeder on that wheel while it's locked. If it then turns free the problem is hydraulic pressure not releasing . If it stays locked it's a mechanical problem inside the drum. Good luck
vintagetrk
Apr 28, 2018
280
US
nathan
#17
I have fought the same issue and like 56STK said, I have chased it back to being something in the master cylinder. I either have something flipped and its not allowing fluid to return or possible an obstruction or air in a line? My solution is to update the system to either Bendix 11" self adjustors or front disk rear drum setup.
Ckelley254
Mar 23, 2016
147
Severance, Colorado
Chris
#18
Update:
After putting the front shoes in the correct position, and bleeding and adjusting the brakes, everything worked well...for three weeks. Yesterday I was driving back from Fort Collins and had to brake hard. The front drivers side pulled hard and I had a come to Jesus moment as the wagon was hurled to the left. Luckily I was able to control it. Also, after initial braking, if I let up on the pedal and then re-brake the vehicle seems to brake "true " or at least more even and straight
So could my bearings on the right front be needing replaced? They looked decent and I re-greased them when I put everything back together.
I'm thinking a front disc conversion will be in the future, but not the immediate future. Any thoughts...
Feb 12, 2016
1,199
North Lawrence,Ohio
Frank
#19
When I adjust my brakes I take the truck out to a safe area and brake hard a couple of times. You can even out the application of the brakes by further adjustment. If the side that locks up is not dragging I would tighten up the opposite side rather than loosen the tight side. Keep messing with the adjustments to get the application even side to side. Brakes pulling to one side can happen with even modern braking systems.
Check you're air pressure in the tires. A low tire will cause it to pull also.
Also do some research on the disc brake conversion. With out a booster you may be disappointed in the results.
Good luck.
56STK
Sep 26, 2010
45
So is it brakes staying on/dragging or is it a pull to one side? There is a difference
